Cooling Performance
Our test kit includes an ATI Radeon HD 5870 1GB graphics card and an Intel Core i7-870 CPU, which has been overclocked from 2.93GHz to 3.4GHz using a vcore of 1.305V and a CPU PLL of 1.9V. This is a modest overclock, but our test kit will spend most of its life under high load, so pushing it too far isn't in anybody's interests. More importantly, some poorer-performing cases push the CPU temperature to above 80°C, so even this overclock will prove to be too much for some cases.
The CPU is cooled by a Gelid Tranquillo CPU cooler with a Noctua NF-S12B ULN 120mm fan. The NF-S12B ULN is a low-airflow fan, so it will highlight cases with poor cooling for the CPU. We also locked the fan speed on the graphics card to 30 per cent to prevent the automatic speed control interfering with the results.
We record the temperature of the CPU using
RealTemp, noting the temperature of the hottest core, and used
GPU-Z to log the temperature of the graphics card. Having recorded the ambient temperature in front of the main air intake of each case, we're then able to calculate the delta T - the difference between the ambient temperature of our lab and the temperature of the hardware. To load the system, we use a combination of the Unigine Heaven benchmark and the Small FFT test in Prime 95.
- CPU:
  Intel Core i7-870 CPU overclocked to 3.4GHz
- Graphics card: ATI Radeon HD 5870 1GB
 - Motherboard: Biostar TPower I55
 - RAM: 2 x 2GB OCZ 1,866MHz DDR3
 - SSD: Corsair Force GT 60GB
 - Hard drive: 160GB Seagate Barracuda 7200.9
 - Heatsink: Gelid Tranquillo with a Noctua NF-S12B ULN fan
 - Power supply: Antec Signature SG-650
        SilverStone Fortress FT04 (max speed)
        SilverStone Raven RV04 (max speed)
        SilverStone Fortress FT04 (min speed)
        SilverStone Raven RV04 (min speed)
        Fractal Design Core 3000 (max speed)
        Corsair Carbide Air 540
        NZXT Phantom 630 (max speed; no HDD cage)
        Corsair Obsidian 900D
        NZXT Phantom 820 (max speed)
        Chieftec DX-02B (max speed)
        Fractal Design Arc Midi R2 (max speed; no HDD cage)
        In Win Tou (max speed)
        Corsair Obsidian 750D
        Corsair Graphite 230T
        Fractal Design Define R4 (max speed; no HDD cage)
        Phanteks Enthoo Primo
        Chieftec DX-02B (min speed)
        Fractal Design Define XL R2 (max speed; no HDD cage)
        Antec P100 (high speed)
        Fractal Design Core 3000 (min speed)
        NZXT Phantom 630 (min speed)
        NZXT Source 530
        Corsair Carbide 330R
        NZXT Phantom 820 (min speed)
        Xigmatek Midgard II (max speed; no HDD cage)
        In Win Tou (min speed)
        NZXT H630
        In-Win G7 (max speed)
        Nanoxia Deep Silence 2 (max speed)
        Fractal Design Arc Midi R2 (min speed)
        Antec P100 (low speed)
        Nanoxia Deep Silence 1 (max speed; ventilated)
        Fractal Design Define R4 (min speed)
        Cooltek Antiphon (max speed)
        Fractal Design Define XL R2 (min speed)
        NZXT H230
        Xigmatek Midgard II (min speed)
        BitFenix Ronin
        In-Win G7 (min speed)
        Nanoxia Deep Silence 1 (min speed)
        Nanoxia Deep Silence 2 (min speed)
        Cooltek Antiphon (min speed)
    °C, lower is better
        NZXT H630
        NZXT Source 530
        NZXT H230
        BitFenix Ronin
    °C, lower is better
Read our
performance analysis on the next page.
